[GRASS-user] Converting Vector to Raster
nik at nikosalexandris.net nik at nikosalexandris.net
Mon Jul 1 11:41:38 PDT 2013
> Pedro Camargo wrote:
> Hi,
Hello Pedro,
> I am trying to convert a vector file (areas for FAF (Freight Analysis
> framework) regions in the US) to raster, but the results I get are quite
> weird.
> The results are attached.
> I think that the issue is that I’d have to set a resolution for the raster
> file (pixel size), but I did not find a place where I could do so.
Correct.
> Any help would be greatly appreciated.
You have to use g.region
(<http://grass.osgeo.org/grass64/manuals/g.region.html>) to set the resolution
and the extent upon which (almost) all raster modules will work on.
For example, given your Location "measures" meters  -- you can confirm that
with  "g,proj -p"  -- it could be something like 0.5km:
g.region vect=FAF_map res=500 -p
Best, Nikos
