[GRASS-user] GUI startup problems
Hamish
hamish_b at yahoo.com
Thu Jul 4 00:23:03 PDT 2013
>> Chiara wrote:
>>> while starting grass, I get this message:
>>> Starting GRASS ...
>>> ERROR: G_getenv(): Variable LOCATION_NAME not set
>>> Traceback (most recent call last):
>>> self._set_properties()
>>> File "/usr/lib/grass64/etc/wxpython/gis_set.py", line 221,
> in
>>> _set_properties
>>> not os.path.isdir(os.path.join(self.gisdbase, location)):
>>> File "/usr/lib/python2.7/posixpath.py", line 66, in join
>>> if b.startswith('/'):
>>> AttributeError: 'NoneType' object has no attribute
> 'startswith'
>>> Error in GUI startup. If necessary, please
>>> report this error to the GRASS developers.
>>> Switching to text mode now.
Chiara:
> g.gui works correctly, and also X0 is there
> actually I could export the jpeg as I wanted
> so... the error causes no problem but it's there
> maybe will fix it installing the next version or updates
> yes, its GRASS 6.4.3 and i have the repositories of ubuntugis enabled
> thanks for the tips!!! :)
maybe try removing the ~/.grassrc6 file? does your user name, or mapset
path have accented letters in it? It doesn't like that much.
Hamish
