[GRASS-user] empty values from v.what.vect
    manuel.martin
    manuel.martin at orleans.inra.fr
    Thu Jul  4 01:21:52 PDT 2013
Dear all,
i am using the d.what.vect function in order to update the "smu" field
of the attribute table of a vector map named "rmqs_to_million", from the
values of the field "SMU" of the third layer (attribute table) of a
vector map called "million".
The type of both the smu and the SMU fieds is integer
here is the piece of code :
v.what.vect vector=rmqs_to_million column=smu qlayer=3 qvect=million
qcolumn=SMU dmax=1000
The output looks ok :
GRASS 6.4.3RC3 (lambertWgs84):~/dev > v.what.vect vector=rmqs_to_million
column=smu qlayer=3 \
 > qvect=million qcolumn=SMU dmax=1000
  100%
  100%
  100%
2193 categories with more than 1 feature in vector map <rmqs_to_million>
2193 categories read from the map
2193 categories exist in the table
2193 categories read from the map exist in the table
2193 records updated
v.distance complete.
But when I look at the rmqs_to_million attribute table, the smu field is
empty.
-> This does not depends on the value used for dmax
-> This does not depends on the field (assuming it of of type integer) I
use from the 3rd layer of the million map
-> This does not depends on the qlayer which the field used for updating
belongs to
I tried to do the same with a vector map having only one attribute table
(layer), and this time, I was successful.
Thus I wonder if there is not a problem with the d.what.vect function
when vector maps with multiple layers are used for updating a field of
the attribute table of another map?
I had this problem with both grass6.4 and 7 under Ubuntu 12.04.
Cheers,         Manuel
----------------0----0------
INRA - InfoSol
Centre de recherche d'Orléans
2163 Avenue de la Pomme de Pin
CS 40001 ARDON
45075 ORLEANS Cedex 2
tel : (33) (0)2 38 41 48 21
fax : (33) (0)2 38 41 78 69
http://www.gissol.fr
----0----0------------------
