[GRASS-user] dbase driver in grass7
Sören Gebbert
soerengebbert at googlemail.com
Thu Jul 4 05:30:33 PDT 2013
2013/7/4 Hamish <hamish_b at yahoo.com>
> Levente wrote:
> > I was wondering about re-compiling GRASS7. I don't know if it is
> > possible to compile it with the dbf connection as default.
> see include/dbmi.h: #define DB_DEFAULT_DRIVER "sqlite"
> and include/temporal.h: #define TGISDB_DEFAULT_DRIVER "sqlite"
The TGISDB_DEFAULT_DRIVER can not be set to dbf. It works only with sqlite
and postgresql (pg). But i am absolutely sure that you do not need to set
the TGIS default driver.
Best regards
Soeren
> change to "dbf".
> > I think that would solve my problem. What do you think?
> > Does it make any sense?
> typically just running db.connect early on to set the default database for
> the mapset in the $MAPSET/VAR file is enough. (or pre-seed that VAR file
> into the new mapset dir yourself)
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- n�chster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130704/19aa844a/attachment.html>
