[GRASS-user] dbase driver in grass7
Hamish hamish_b at yahoo.com
Thu Jul 4 05:05:32 PDT 2013
Levente wrote:
> I was wondering about re-compiling GRASS7. I don't know if it is
> possible to compile it with the dbf connection as default.
see include/dbmi.h: #define DB_DEFAULT_DRIVER "sqlite"
and include/temporal.h: #define TGISDB_DEFAULT_DRIVER "sqlite"
change to "dbf".
> I think that would solve my problem. What do you think?
> Does it make any sense?
typically just running db.connect early on to set the default database for the mapset in the $MAPSET/VAR file is enough. (or pre-seed that VAR file into the new mapset dir yourself)
Hamish
