[GRASS-user] unexpected i.pansharpen results
Nikos Alexandris
nik at nikosalexandris.net
Sun Jul 28 16:45:34 PDT 2013
Eric Goddard wrote:
> > I gave up on that pansharpening attempt. I can test some of my imagery
> > tomorrow and let you know if I still have issues with it.
Nikos Alexandris wrote:
> [rest deleted]
> I can't get any decent looking colors, with any of the methods. I wonder if
> my images are not properly "aligned" or the like. PCA seems to approach it
> right -- the value ranges seem to fit the reflectance scheme (below 1.0)
> but the colors are so fancy... ?
> Will work on it later in the evening.
To-day/-night I got it to work with 11-bit images! I rescaled them to [0,
255] and that seems to work just fine. Even color rebalancing (i.e. of Blue,
Green and Red fusioned with Pan -IKONOS spectral bands) after the sharpening
appears acceptable.
A bit skeptical though since the rescaling action throws away some of the
data's details... :-?
All of my other attempts using out of [0, 255] range values, for example using
Top-of-Atmosphere Reflectances (floating point values < 1.0) or the raw
IKONOS bands that range between [0, 2047], were not successful.
So, does i.pansharpen expect only 8-bit images? Can someone confirm or
reject?
Thanks, Nikos
