[GRASS-user] r.in.wms and PCN webservices
Ivan Marchesini
ivan.marchesini at gmail.com
Sat Jun 1 05:51:40 PDT 2013
Many thanks stephan.. I will try with the new release.. Ciao
inviato da smartphone
Il giorno 31/mag/2013 18:52, "Štěpán Turek" <stepan.turek at seznam.cz> ha
scritto:
> Hi Ivan and pierluigi,
> Hy pierluigi
> a web GET request is made of a url and, after a "?", of a set of params.
> I think that r.in.wms try to put a "?" at the and of the url.
> but the wms address you use already contain a "?"
> so you have to use, for the url, only the http addrees and, for the
> urlparams, the remaining part of the address.
> it worked as you described, however GetCapabilities request ignored
> urlparams parameter. After r56519 it should be able also to use url with
> "?". GetCapabilities request should also work both ways now (r56520) (using
> urlparams or including parameters directly into url).
> Best
> Stepan
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130601/f5c524e1/attachment.html>
