[GRASS-user] startup error
Anna Petrášová
kratochanna at gmail.com
Wed Jun 5 11:44:38 PDT 2013
On Wed, Jun 5, 2013 at 8:21 PM, david adam <david at quercus.org> wrote:
> Greetings!
> Whenever I start up GRASS 6.4.2 using Fedora 18 I get the message:
> Cleaning up temporary files ...
> Starting GRASS ...
> (python:10541): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion
> `GTK_IS_WIDGET (widget)' failed
> and then the system starts running. Is this something I need to fix? If
> so, how should I proceed?
these messages are usually harmless. If you don't have other problems, just
ignore it.
Regards,
Anna
tia,
> David Adam
> ______________________________**_________________
> grass-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130605/51a639e5/attachment.html>
