[GRASS-user] NDVI analyses with Landsat 8
Nikos Alexandris
nik at nikosalexandris.net
Wed Jun 12 14:58:44 PDT 2013
Huub Munstege wrote:
> Hello Nikos,
Hello Huub!
> thx for the swift reply. I'll check out the options you mentioned but at
> first sight I noticed that 'i.vi' tool is not available for me ( I'am on
> 6.4.3-rc, from the AUR package in Archlinux). I.vi is not a command in the
> 'standard' Grass trunk. Neither is it available as an add-on.
Right! Apologies from my side. I have a setup giving access to all grass
modules outside of a grass session [see link to GRASS-Wiki below] which, if
not properly handled, as described in the wiki ("strip paths"), it even allows
access to all grass70 modules from inside a grass64 session.
> Some more explanation as you asked: previous Landsat 7 images we analyzed
> with a simple raster calculation with the following formula:
> float(Band-4 - Band-3) / (Band-4 + Band-3).
I guess using grass64 means sticking to the formula above for NDVI.
> But as you already noticed the bands and ranges have changed under Landsat
> 8. Various combinations of bands (4,5 and 8) give a result that is at best
> not so clear cut as the analysis done with L-7.
I didn't test any L8 so far, though I have downloaded some scenes. Strange,
in a way -- I would rather think that their improvements would improve S-N-R
and, thus, derive "better" vegetation indices... :-?
> The "bluntly subtraction with 0.12" is based on on a quick scan of the
> obtained result. Areas without vegetation in our project area should give
> values in the range between -0.05 - 0.
as per L7 data I guess...
> The result of the combination of the 5 and 4 bands in the above formula
> gives values that are aprroximately 0.12 higher.
I see.
> Therefore the blunt and in-elegant subtraction which is definitely wrong.
> But it gives us for the time being a better deistinction between cultivated
> irrigation schemes and their surroundings. Maybe I am simply too impatient
> and too eager to work with the new fresh data from L-8.
Sorry for asking again: did you correct the data in some way or did you
simply feed the formula with DNs?
> Undoubtedly soon, Grass and the other software will incorporate specific
> modules that will be tailored to the L-8 sensors.
> Cheers and keep up the good work,
Thank you for all of the details regarding your work.
Nikos
<http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#Bash_examples_.28GNU.2FLinux.29>
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130613/ebd8fdd6/attachment.pgp>
