[GRASS-user] r.le.out subdirectory
Hamish
hamish_b at yahoo.com
Thu Jun 20 05:40:02 PDT 2013
Johannes wrote:
> I just wanted to try out the r.le.* tools for a simple
> analysis of habitat patch patterns. In this context,
> I was not able to find out where this r.le.out
> subdirectory is located where all the result tables
> are stored? Should this be a subdirectory
> within the mapset?
I'm not sure, maybe relative to the
directory you start the module from.
Try 'mkdir'-ing r.le.out/ first, then
running from pwd. (make sure you have
write permissions there.
Hamish
