[GRASS-user] r.le.out subdirectory
    José Miguel Barrios
    jmbarriosg at gmail.com
    Thu Jun 20 05:44:57 PDT 2013
Indeed. With pwd you can get to know where the r.le.out directory is
created. The r.le.para directory with the settings (units size, units form,
etc) is also created there.
Miguel
2013/6/20 Hamish <hamish_b at yahoo.com>
> Johannes wrote:
> > I just wanted to try out the r.le.* tools for a simple
> > analysis of habitat patch patterns. In this context,
> > I was not able to find out where this r.le.out
> > subdirectory is located where all the result tables
> > are stored? Should this be a subdirectory
> > within the mapset?
> I'm not sure, maybe relative to the
> directory you start the module from.
> Try 'mkdir'-ing r.le.out/ first, then
> running from pwd. (make sure you have
> write permissions there.
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130620/d4978211/attachment-0001.html>
