[GRASS-user] r.le.out subdirectory
    Johannes Radinger
    johannesradinger at gmail.com
    Thu Jun 20 06:20:01 PDT 2013
Thank you for the fast response. It is indeed the pwd.
/Johannes
On Thu, Jun 20, 2013 at 2:44 PM, José Miguel Barrios
<jmbarriosg at gmail.com>wrote:
> Indeed. With pwd you can get to know where the r.le.out directory is
> created. The r.le.para directory with the settings (units size, units form,
> etc) is also created there.
> Miguel
> 2013/6/20 Hamish <hamish_b at yahoo.com>
>> Johannes wrote:
>> > I just wanted to try out the r.le.* tools for a simple
>> > analysis of habitat patch patterns. In this context,
>> > I was not able to find out where this r.le.out
>> > subdirectory is located where all the result tables
>> > are stored? Should this be a subdirectory
>> > within the mapset?
>> I'm not sure, maybe relative to the
>> directory you start the module from.
>> Try 'mkdir'-ing r.le.out/ first, then
>> running from pwd. (make sure you have
>> write permissions there.
>> Hamish
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130620/cbe36c33/attachment.html>
