[GRASS-user] How to plot a vector field?
david adam
david at quercus.org
Thu Jun 27 20:02:40 PDT 2013
Many Thanks! Guessing would not have worked here...
david
On 06/27/2013 05:07 PM, Hamish wrote:
> David wrote:
>> I would like to plot data which consist of a number of points, each of
>> which has a latitude, a longitude, an x-velocity, and a y-velocity. I
>> want to plot an arrow for each point that starts at the proper latitude
>> and longitude, and has a length and direction that show the velocity. I
>> used to think of these as vector values, but in GRASS a vector is
>> something else. What is the proper GRASS terminology for this kind of
>> data? What modules do this kind of plot?
> Hi,
> use the d.barb module from GRASS 6 addons.
> http://grasswiki.osgeo.org/wiki/AddOns/GRASS_6#d.barb
> x and y components of velocity are given using attribute column names
> in the u= and v= parameters when a GRASS vector (i.e. sparse points)
> input= map is given.
> "vector maps" mean defined by coordinates, so points, lines, and areas.
> "raster maps" mean defined by 2D or 3D array, so constant grids and pixels.
> d.barb will work with both GRASS raster and vector points maps,
> the meaning of the u=, v= parameters changes according to the context.
> Usage:
> d.barb [-r] [direction=name] [magnitude=name] [u=name] [v=name]
> [input=name] [layer=value] [style=string] [color=name] [skip=value]
> [scale=value] [peak=value] [aspect_type=string]
> [legend_at=x,y[,x,y,...]] [legend_velo=value[,value,...]]
> [legend_fontsize=value] [--verbose] [--quiet]
> Flags:
> -r Rotate direction 180 degrees
> Useful for switching between atmospheric and oceanographic conventions
> --v Verbose module output
> --q Quiet module output
> Parameters:
> direction Raster map (or attribute column) containing velocity direction
> magnitude Raster map (or attribute column) containing velocity magnitude
> u Raster map (or attribute column) containing u-component of velocity
> v Raster map (or attribute column) containing v-component of velocity
> input Name of input vector map
> layer Layer number
> A single vector map can be connected to multiple database tables. This number determines which table to use.
> default: 1
> style Style
> options: arrow,barb,small_barb,straw
> default: arrow
> color Color
> Either a standard color name or R:G:B triplet
> default: black
> skip Draw arrow every Nth grid cell
> default: 10
> scale Scale factor for arrow rendering
> default: 1.0
> peak Maximum value for scaling (overrides map's maximum)
> aspect_type Direction map aspect type
> options: cartesian,compass
> default: cartesian
> legend_at Screen percentage for legend barb ([0,0] is bottom-left)
> Draws a single barb and exits
> options: 0-100
> default: 10.0,10.0
> legend_velo Velocity for legend key arrow
> legend_fontsize Font size used in legend
> default: 14
> it's still a work in progress, but ~90% of the features are working.
> Hamish
