[GRASS-user] Environment variables to use grass from python on windows
Pierric pierric7 at yahoo.com
Fri Jun 28 02:46:20 PDT 2013
Hello,
I am trying to run a Python script which uses Grass library. I must say that grass was installed on my machine (windows 7) through installation of QGIS. Hence the Grass main folder is located in C:\Program Files (x86)\Quantum GIS Lisboa\apps\grass\grass-6.4.2
Here is the python code I tried to use to set up the environment variables. Unfortunately when running the last line "import grass.script" , I get an error message saying that grass library could not be found. I have tried different things but I cant figure out what I am missing.
import os,sys,atexit,time
os.environ['GISBASE'] = 'C:\\Program Files (x86)\\Quantum GIS Lisboa\\apps\\grass\\grass-6.4.2'
os.environ['GISRC'] = 'C:\Users\Pierric\AppData\Roaming\GRASS6\grassrc6'
os.environ['LD_LIBRARY_PATH'] = os.path.join(os.environ['GISBASE'],'lib')
os.environ['PATH'] = os.environ['PATH']+';%s\\etc;%s\\etc\\python;%s\\lib;%s\\bin;%s\\bin;C:\\Program Files (x86)\\Quantum GIS Lisboa\\apps\\msys\\bin;C:\\Python27;%s\\etc\\python\\grass;%s\\etc\\python\\grass\\script;%s\\etc\\python\\grass\\lib' % ((os.environ['GISBASE'],)*8)
os.environ['GRASS_SH'] = 'C:\Program Files (x86)\Quantum GIS Lisboa\apps\msys\bin\sh.exe'
os.environ['PYTHONLIB'] = 'C:\Python27'
os.environ['PYTHONPATH'] = os.path.join(os.environ['GISBASE'],'etc','python')
import grass.script as grass
