[GRASS-user] i.maxlik
    Markus Neteler
    neteler at osgeo.org
    Sun Mar  3 02:37:04 PST 2013
On Wed, Feb 13, 2013 at 12:27 PM, Johannes Radinger
<johannesradinger at gmail.com> wrote:
> Hi
> On Wed, Feb 13, 2013 at 10:36 AM, Rebecca Stedham
> <rlstedham at btinternet.com> wrote:
>> Hello,
>> I am running i.maxlik in python - attempting to automate a processing chain.
>> I use the command:
>> grass.run_command('i.maxlik', group= group, subgroup=subgroup,
>> class='classification', sigfile = sigfile, verbose = True)
>> Infuriatingly, however 'class' is a python keyword and it doesn't run due to
>> 'invalid syntax'.
> I had a similar issue with v.distance which uses 'from', another python keyword.
> Here the pythoncode is '_from' which looks like:
> grass.run_command("v.distance",_from="xxx",to="xxx",...)
> Maybe there is something similar for class ('_class'?) in i.maxlik.
Here a solution was suggested:
http://gis.stackexchange.com/questions/50753/is-there-a-workaround-for-grass-i-maxlik-class-being-a-keyword-in-python
Discussion to be continued in the grass-dev list, I have already
posted there.
Markus
