[GRASS-user] error building recent grass-svn versions
Vincent Bain
bain at toraval.fr
Mon Mar 4 09:30:39 PST 2013
for some weeks now, when compiling grass64_release on my debian 64 bit
Squeeze, make encounters errors :
Errors in:
/usr/local/src/grass64_release/lib/ogsf
/usr/local/src/grass64_release/lib/nviz
/usr/local/src/grass64_release/misc/m.nviz.image
/usr/local/src/grass64_release/visualization/nviz
Making little use of nviz, it is not an emergency but I'd like to fix it
now. I fear the problem has something to do with avformat libs.
I tried to cd to lib/ogsf, then make clean, then make. The following
error occurs :
In file included from gsd_img_mpeg.c:28:
/usr/include/libavformat/avformat.h:158: warning: ‘AVMetadata’
is deprecated
gsd_img_mpeg.c: In function ‘add_video_stream’:
gsd_img_mpeg.c:64: warning: assignment makes pointer from
integer without a cast
gsd_img_mpeg.c: In function ‘gsd_init_mpeg’:
gsd_img_mpeg.c:375: error: ‘AVIO_FLAG_WRITE’ undeclared (first
use in this function)
gsd_img_mpeg.c:375: error: (Each undeclared identifier is
reported only once
gsd_img_mpeg.c:375: error: for each function it appears in.)
make: *** [OBJ.x86_64-unknown-linux-gnu/gsd_img_mpeg.o] Erreur 1
The current version of libavformat-dev is 5:0.7.15-dmo1
Can anyone help me with this issue ? should I try to force a more recent
version of the lib, or is the problem somewhere else ?
Thank you,
Vincent
