[GRASS-user] error building recent grass-svn versions
Glynn Clements
glynn at gclements.plus.com
Mon Mar 4 13:20:31 PST 2013
Vincent Bain wrote:
> gsd_img_mpeg.c:375: error: ‘AVIO_FLAG_WRITE’ undeclared (first
> use in this function)
> gsd_img_mpeg.c:375: error: (Each undeclared identifier is
> reported only once
> gsd_img_mpeg.c:375: error: for each function it appears in.)
> make: *** [OBJ.x86_64-unknown-linux-gnu/gsd_img_mpeg.o] Erreur 1
> The current version of libavformat-dev is 5:0.7.15-dmo1
> Can anyone help me with this issue ? should I try to force a more recent
> version of the lib, or is the problem somewhere else ?
If you don't need the ability to write video files, don't use
--with-ffmpeg.
Otherwise, you'll need a more recent version of the libraries.
