[GRASS-user] error building recent grass-svn versions
Vincent Bain
bain at toraval.fr
Mon Mar 4 23:03:42 PST 2013
Thank you Glynn for your answer, I'll trim my configure command.
If I ever need to output video, what is the minimum version of avcodec
to build against ?
Vincent
Le lundi 04 mars 2013 à 21:20 +0000, Glynn Clements a écrit :
> Vincent Bain wrote:
> > gsd_img_mpeg.c:375: error: ‘AVIO_FLAG_WRITE’ undeclared (first
> > use in this function)
> > gsd_img_mpeg.c:375: error: (Each undeclared identifier is
> > reported only once
> > gsd_img_mpeg.c:375: error: for each function it appears in.)
> > make: *** [OBJ.x86_64-unknown-linux-gnu/gsd_img_mpeg.o] Erreur 1
> > The current version of libavformat-dev is 5:0.7.15-dmo1
> > Can anyone help me with this issue ? should I try to force a more recent
> > version of the lib, or is the problem somewhere else ?
> If you don't need the ability to write video files, don't use
> --with-ffmpeg.
> Otherwise, you'll need a more recent version of the libraries.
