[GRASS-user] i.histo.match error
Nikos Alexandris nik at nikosalexandris.net
Tue Mar 5 09:22:38 PST 2013
Luís Mário Ribeiro wrote:
> Been using histo.match thru the GUI. The command that appears in the output
> window is (in this example just 3 images):
> i.histo.match
> input=normalized.LT52030312007052MPS00_tr_reflec3_int at histomatch,normalized.
> LT52030312007052MPS00_tr_reflec4_int at histomatch,normalized.LT52030312007180
> M PS00_tr_reflec3_int at histomatch max=1000
I guess (not sure though) it is the same error once pointed to me by Luca
Delucchi:  the "." in the input raster map names is not allowed :-(.
You need to rename them...  Maybe a quick test first to be sure.  Shrink your
region and test.  Be sure you have beforehand a MASK or else which you use to
set the computational region.  Or, export your current working region in a
vector map?  (<-- v.in.region).
Hope it works, Nikos
