[GRASS-user] i.histo.match error
Luís Mário Ribeiro
luis.mario at adai.pt
Wed Mar 6 01:29:33 PST 2013
[>]Good morning and thanks... Will try changing the "." (which was added by
Grass when performing i.topo.corr).
Best regards, luis
Luís Mário Ribeiro wrote:
> Been using histo.match thru the GUI. The command that appears in the
> output window is (in this example just 3 images):
> i.histo.match
input=normalized.LT52030312007052MPS00_tr_reflec3_int at histomatch,normalized.
> LT52030312007052MPS00_tr_reflec4_int at histomatch,normalized.LT520303120
> 07180 M PS00_tr_reflec3_int at histomatch max=1000
I guess (not sure though) it is the same error once pointed to me by Luca
Delucchi: the "." in the input raster map names is not allowed :-(.
You need to rename them... Maybe a quick test first to be sure. Shrink
your region and test. Be sure you have beforehand a MASK or else which you
use to set the computational region. Or, export your current working region
in a vector map? (<-- v.in.region).
Hope it works, Nikos
