[GRASS-user] preserving original resolution with r.in.gdal
    Nikos Alexandris
    nik at nikosalexandris.net
    Thu Mar  7 09:45:35 PST 2013
On Thursday 07 of March 2013 12:08:48 Jitendra Kumar wrote:
> Hello GRASS-Users:
Hello Jitu!
> While importing a raster map using "r.in.gdal" it uses the resolution of
> the current region for the resulting raster map.
Are you sure?  What does r.info say about the imported map?  Out of the top of
my head, I don't think that the current region settings affect a maps extent
and resolution while importing.  They shouldn't.
> Is there a way to preserve the original resolution of the raster while
> importing it in irrespective of the settings of the current region.
> I can check the resolution of the raster to be imported using "gdalinfo",
> set my current region appropriately and then import it using "r.in.gdal".
I guess there is no need to do so.
> But I was wondering if there's a easier way to tell the import routine to
> preserve the original resolution. Same question applies while reprojecting
> a raster using "r.proj".
r.proj is another beast -- there you can either depend on the current region
settings (in the Location/Mapset where you are reprojecting raster data to) or
use the "res=" parameter provided by the r.proj module.
Best, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130307/be059eac/attachment.pgp>
