[GRASS-user] r.resamp.rst error : "Not enough disk space--cannot write files"
    bidon sanshuile
    piano_bo at hotmail.com
    Sun Mar 10 11:41:21 PDT 2013
> Date: Sun, 10 Mar 2013 16:28:49 +0100
> Subject: Re: [GRASS-user] r.resamp.rst error : "Not enough disk space--cannot write files"
> From: markus.metz.giswork at gmail.com
> To: piano_bo at hotmail.com
> CC: grass-user at lists.osgeo.org
> On Sun, Mar 10, 2013 at 9:33 AM, bidon sanshuile <piano_bo at hotmail.com> wrote:
> > Hello,
> > I'm in an internship for a marine institute and try to calculate the
> > sandwaves migration rate.
> > Everything was ok until today. I am confronted to a difficulty I cannot
> > manage.
> > When I try to use the tool "r.resamp.rst", it gives me as answer:
> > r.resamp.rst input=map at PERMANENT ew_res=11 ns_res=11 pcurv=curv
> > Processing all selected output files will require
> Note that this message:
> > 261320 bytes of disk space for temp files.
> is bogus for large regions with fine resolution because of integer
> overflow (fixed in trunk).
> How many cells are in your current region with resolution=11?
Thank you for your answers!
Here are the characteristics of the raster:
 |   Rows:         3062                                                       |
 |   Columns:      2587                                                       |
 |   Total Cells:  7921394
I don't know how many of these have a resolution of 11.. I am following a step by step manual where they advise to set ew_res at this value.
>> What filesystem? FAT32 cannot support files larger than 4 GiB; NTFS shouldn't have any problems.
My two hard discs are NTFS
> > Temporarily changing the region to desired resolution ...
> > Changing back to the original region ...
> > Percent complete:
> > interpolate() failed
> > dnorm in mainc after grid before out1= 12.961481
> > ERROR: split_and_interpolate() failed
> > I have 14GB left on my hard disk so I don't understand why they are saying
> > me that :/
> > I tried to find solution, and I found some answers (e.g. here :
> > http://lists.osgeo.org/pipermail/grass-dev/2005-April/018152.html)
> > but I dont understand ^^
> > They speak about a "ulimit -f" function, but where should I write it ? It
> > doesn't work in GRASS.
> > I am on windows, maybe is that the problem.
> > SO in conclusion, I am more than lost so if someone could help me it would
> > be perfect!
> > Thank you,
> > b.raoul
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130310/4edd2a27/attachment-0001.html>
