[GRASS-user] Is Kyngesburye's binary for Mac GDAL compatible with GRASS 7?
William Kyngesburye woklist at kyngchaos.com
Tue Mar 26 06:41:51 PDT 2013
If you are installing binaries, there is no compilation involved by you.  I meant if Barton's GRASS says my GDAL 1.9.2 (the current version), and I package a GDAL 1.9.3, that will also work, but a GDAL 1.10 will not.
On Mar 26, 2013, at 7:59 AM, gregory.penn at gmail.com wrote:
> Thanks, William. Would you please explain what you meant when you wrote, ". .
> . as long as you match the GDAL major version specified"? Is that a
> parameter that I have to set in the compilation process? I'm new to this and
> apologize if the question is terribly naive.
> Gregory
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed robot?
[Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
