[GRASS-user] older grass 7 release
Chad Ferguson terrafergus at gmail.com
Tue Mar 26 12:03:45 PDT 2013
Markus,
Yes, I was trying on Ubuntu 12.04, using the current svn at
ubuntugis-testing.  Here are the messages I am receiving
When running g.extension I receive the following error(s). (I tried a
couple extensions to make sure the error was not native to r.geomorphon) :
(Thu Mar  7 21:05:45 2013)
g.extension extension=r.geomorphon
operation=add
  File "/usr/lib/grass70/scripts/g.extension", line 1061, in
<module>
    sys.exit(main())
  File "/usr/lib/grass70/scripts/g.extension", line 1048, in
main
    check_dirs()
  File "/usr/lib/grass70/scripts/g.extension", line 942, in
check_dirs
    check_style_files('grass_logo.png')
  File "/usr/lib/grass70/scripts/g.extension", line 923, in
check_style_files
    shutil.copyfile(dist_file, addons_file)
  File "/usr/lib/python2.7/shutil.py", line 82, in copyfile
    with open(src, 'rb') as fsrc:
IOError: [Errno 2] No such file or directory:
'/usr/lib/grass70/docs/html/grass_logo.png'
(Thu Mar  7 21:05:45 2013) Command finished (0 sec)
When trying to install using make in the terminal I receive the following
error:
chad at chad-Satellite-S855:~/gisData/r.geom$ make
MODULE_TOPDIR=/usr/lib/grass70
/usr/lib/grass70/include/Make/Rules.make:15: target
`/build/buildd/grass70-7.0/debian/tmp/usr/lib/grass70/bin' given more than
once in the same rule.
mkdir -p /build/buildd/grass70-7.0/debian/tmp/usr/lib/grass70
CHad
On Tue, Mar 26, 2013 at 2:50 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Mar 26, 2013 at 7:27 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> >>The author of r.geomorphons may
> >>help here, the module is not in the GRASS Addons repository.
> > it is:
> http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.geomorphon
> ah, without the plural s...
> > but not linked to the addons-wiki...
> ok, someone will fix it :)
> I tried on Fedora, no real problem:
> GRASS 7.0.svn (loc_ncarolina_spm_base0.3.1):~/grass70 > g.extension
> r.geomorphon
> Fetching <r.geomorphon> from GRASS-Addons SVN (be patient)...
> Compiling...
> (many warnings which suggest a code cleanup being recommended)
> Installing...
> Updating metadata file...
> Installation of <r.geomorphon> successfully finished
> Again an Ubuntu specific problem? Error messages would be needed to help.
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130326/7d3ad4db/attachment.html>
