[GRASS-user] RE : GRASS 6.4 Windows - How to change current directory
Daniel Victoria daniel.victoria at gmail.com
Wed Mar 27 09:46:57 PDT 2013
Hi Lucien,
I sent the email but I did not test. Now I'm sitting in front of my winbox
and indeed, it does not work.
In winGrass v7 the command terminal is kept open so you can issue commands
like change directory and the likes. But I'm not able to do it in 6.4
Daniel
On Wed, Mar 27, 2013 at 1:20 PM, BLANDENIER Lucien <
lucien.blandenier at unine.ch> wrote:
> Hi Daniel,
> Thank you for your suggestion but it neither works.
> Others idea?
> ________________________________
> De : Daniel Victoria [daniel.victoria at gmail.com]
> Date d'envoi : mercredi 27 mars 2013 16:54
> À : BLANDENIER Lucien
> Cc: grass
> Objet : Re: [GRASS-user] GRASS 6.4 Windows - How to change current
> directory
> Are you putting a : between the cd and the path (d:\dir)?
> If yes,  remove that :
> Daniel
> On Mar 27, 2013 11:04 AM, "BLANDENIER Lucien" <lucien.blandenier at unine.ch
> <mailto:lucien.blandenier at unine.ch>> wrote:
> Hi all,
> I have some problem to change the current directory on the windows
> terminal. I used cd : d:\directory but I stay in the same directory...
> Do someone knows how to do that on windows?
> Thanks for your help.
> Lucien
> grass-user mailing list
> grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130327/8bc13404/attachment.html>
