[GRASS-user] v.trees3D
Rebecca Bennett
rabennett at ymail.com
Wed Mar 27 14:10:09 PDT 2013
Thanks
for the link Martin.
I
did a bit of digging and found these instructions for adding thev.trees3D add-on without using g.extension
http://les-ejk.cz/programs/?cat=gis
Installation
If
it is an tgzpackage, it is most probably the C-source code:
* Copy the file in the GRASS source directory to proper directory (raster
modules in raster, vector in vectoretc.).
* Untar the archive with tar xzf modulename.tgz
* Go to the new module directory and run make:
cd modulename
make
* Go to the GRASS source directory and run make installfor
installing it.
Can
anyone tell me if these are still valid- I only ask because I don't
see separate directories for raster and vector modules in my install (~usr/lib/Grass64/bin, GRASS version: 6.4.3RC2 on Ubuntu 12.04 precise)?
>________________________________
> From: Martin Landa <landa.martin at gmail.com>
>To: Rebecca Bennett <rabennett at ymail.com>
>Cc: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>; Jachym Cepicky <jachym.cepicky at gmail.com>
>Sent: Wednesday, 27 March 2013, 16:16
>Subject: Re: [GRASS-user] v.trees3D
>Hi,
>2013/3/27 Rebecca Bennett <rabennett at ymail.com>:
>> Does anyone know if the v.trees3D vector add-on (for extruding trees from
>> points) is still accessible? Can't find it in the current svn so I am
>> assuming not... if this is the case does anyone have any other cool
>> suggestions for auto-modelling 3D trees from point data?
>I found the source code of this module at [1] (cc'ed original author
>Jachym Cepicky, could be that he is planning to upload his modules to
>AddOns SVN :-)
>Martin
>[1] http://les-ejk.cz/files/programs/grass/v.trees3d.tar.gz
>Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130327/c56ef404/attachment.html>
