[GRASS-user] v.trees3D
Eric Goddard
egoddard1010 at gmail.com
Wed Mar 27 19:05:06 PDT 2013
Yes that still works--it also works for python modules, but you add it to
wherever you unpacked your grass source code (such as in
~/source/grass_trunk), not where grass is installed. Did you compile grass
or are you using a version from the repos?
Eric
On Mar 27, 2013 4:10 PM, "Rebecca Bennett" <rabennett at ymail.com> wrote:
> Thanks for the link Martin.
> I did a bit of digging and found these instructions for adding the v.trees3D
> add-on without using g.extension
> http://les-ejk.cz/programs/?cat=gis Installation
> If it is an tgz package, it is most probably the C-source code:
> - Copy the file in the GRASS source directory to proper directory
> (raster
> modules in raster, vector in vector etc.).
> - Untar the archive with tar xzf modulename.tgz
> - Go to the new module directory and run make:
> cd modulename
> make
> - Go to the GRASS source directory and run make install for
> installing it.
> Can anyone tell me if these are still valid - I only ask because I don't
> see separate directories for raster and vector modules in my install
> (~usr/lib/Grass64/bin, GRASS version: 6.4.3RC2 on Ubuntu 12.04 precise)?
> *From:* Martin Landa <landa.martin at gmail.com>
> *To:* Rebecca Bennett <rabennett at ymail.com>
> *Cc:* "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>; Jachym
> Cepicky <jachym.cepicky at gmail.com>
> *Sent:* Wednesday, 27 March 2013, 16:16
> *Subject:* Re: [GRASS-user] v.trees3D
> Hi,
> 2013/3/27 Rebecca Bennett <rabennett at ymail.com>:
> > Does anyone know if the v.trees3D vector add-on (for extruding trees from
> > points) is still accessible? Can't find it in the current svn so I am
> > assuming not... if this is the case does anyone have any other cool
> > suggestions for auto-modelling 3D trees from point data?
> I found the source code of this module at [1] (cc'ed original author
> Jachym Cepicky, could be that he is planning to upload his modules to
> AddOns SVN :-)
> Martin
> [1] http://les-ejk.cz/files/programs/grass/v.trees3d.tar.gz
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130327/ba793e21/attachment-0001.html>
