[GRASS-user] Help with installing GRASS 7 on linux mint 14
Eric Goddard
egoddard1010 at gmail.com
Thu Mar 28 05:47:28 PDT 2013
I apologize for the horrible formatting--I didn't think gmail would
insert line breaks if in plain text mode. sorry about that!
I also gave you the incorrect syntax for using ppa-purge to remove the
broken links to ubuntugis-testing. Try this:
sudo ppa-purge ppa:ubuntugis/ubuntugis-testing
I also don't see the ubuntugis-unstable repository in your sources
list. Did you run
sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
sudo apt-get update
Eric
On Thu, Mar 28, 2013 at 5:39 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Mar 28, 2013 at 9:58 AM, דור פרידמן <dof1985 at gmail.com> wrote:
> (btw: no need to post all this message stuff, please reduce to the
> needed minimum)
>> dof1985 at dof1985-K53E ~ $ sudo apt-get install build-essential
>> Reading package lists... Done
>> Setting up libalgorithm-merge-perl (0.08-2) ...
>> dof1985 at dof1985-K53E ~ $ make flex bison gcc libgcc1 g++ cmake ccache python
> Not "make" but "apt-get install ..."
> Ok, I realise that the syntax highlighting was unfortunate, I have tried to
> slightly improve it and added a comment to copy-paste the entire installation
> command:
> http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Current_stable_Ubuntu_version
> Hope it is clear now,
> Markus
