[GRASS-user] gis.m no
Robert Andrew Brown
brown782 at purdue.edu
Thu Mar 28 14:39:33 PDT 2013
I cannot remove this lock from the PERMANENT file below. As a matter of fact I cannot find the .gislock file in the directory.
GRASS 7.0.svn (Llanos):~ > grass70 -gui
Cleaning up temporary files...
Starting GRASS GIS...
WARNING: It appears that the X Windows system is not active.
A graphical based user interface is not supported.
Switching to text based interface mode.
Hit RETURN to continue
Bob is currently running GRASS in selected mapset (file /Users/Bob/grassdata/Llanos/PERMANENT/.gislock found). Concurrent use not allowed.
Any suggestions would be appreciated
On Mar 28, 2013, at 4:06 PM, Martin Landa <landa.martin at gmail.com> wrote:
> [please keep communication on ML]
> 2013/3/28 Robert Andrew Brown <brown782 at purdue.edu>:
>> So when I start up grass it should automatically com up? It does no launch like it used to when I had an older version of GRASS. I also had compiled other software and replace my wxwidgets with a newer version. After, that is when the grass would no longer automatically open the location wizard and the Layer Manager automatically!
>> I will have to look It seems like I deleted my python 2.6 for the compilation of the other software and then had to reinstall for the GRASS installation I am wondering if that might be the issue.
>> Anyhow Thanks again!
>> -bob
>> On Mar 28, 2013, at 2:53 PM, Martin Landa <landa.martin at gmail.com> wrote:
>>> Hi,
>>>> Is there some setting to turn the location wizard on or a command in -bash? Cannot seem to find it!
>>> no, currently Location Wizard is only available from welcome screen
>>> and Layer Manager menu.
>>> Martin
>>> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
