[GRASS-user] Fill area between isolines?
Tim Michelsen
timmichelsen at gmx-topmail.de
Fri Mar 29 08:01:27 PDT 2013
Hello user list,
I have a question filling the area between isolines by the values of the
isolines (without interpolation):
I have a vector with isolines of which the values define certain
properties of the area (e.g. cost factor).
How can I create an area that fills the area between these lines and to
which the same value as the last adjacent line is attached (all points
from one line to the other have the same cost factor)?
I understand that in this case a interpolation is not required.
It would be great to receive some helpful hints and tips on above
outlined question.
Kind regards and thanks in advance,
Timmie
