[GRASS-user] Fill area between isolines?
Markus Metz
markus.metz.giswork at gmail.com
Fri Mar 29 08:40:49 PDT 2013
On Fri, Mar 29, 2013 at 4:01 PM, Tim Michelsen
<timmichelsen at gmx-topmail.de> wrote:
> Hello user list,
> I have a question filling the area between isolines by the values of the
> isolines (without interpolation):
> I have a vector with isolines of which the values define certain
> properties of the area (e.g. cost factor).
> How can I create an area that fills the area between these lines and to
> which the same value as the last adjacent line is attached (all points
> from one line to the other have the same cost factor)?
You could try to
1. set the region, e.g. with g.region vect=name_of_isolines_vector
res=1 -a (adjust resolution to your needs)
2. convert isolines to raster
3. r.grow.distance value=name_of_filled_areas
Markus M
> I understand that in this case a interpolation is not required.
> It would be great to receive some helpful hints and tips on above
> outlined question.
> Kind regards and thanks in advance,
> Timmie
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
