[GRASS-user] Getting raster cell coordinates
Allar Haav allar.haav at gmail.com
Thu May 2 04:40:14 PDT 2013
What would be the most efficient way of getting the coordinates for each
input raster cell? I'm using this in a Python script that creates a
separate cost surface (using r.cost) for each cell (yes, that is
computationally intensive thing indeed, but that's not a problem
itself). I've been using a simple function I made that creates a list of
coordinates via iteration starting from the region corner and using
cellsize as a step. But this does not check for null-values in the
raster (which I would like to exclude) and I'm also not very sure how it
would play out with some coordinate systems. One way to solve the
null-value issue would be to impose an r.what check, but this does not
seem to be very elegant way to do it.
Any suggestions? I'm more or less comfortable with using ctypes, so that
route would perhaps be the best in terms of performance.
Regards,
Allar
