[GRASS-user] [GRASS-dev] wxGUI toolboxes
Anna Kratochvílová
kratochanna at gmail.com
Thu May 2 07:40:21 PDT 2013
On Thu, May 2, 2013 at 10:11 AM, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
> Hi Anna,
> 2013/5/2 Anna Kratochvílová <kratochanna at gmail.com>
>> On Thu, May 2, 2013 at 9:52 AM, Sören Gebbert
>> > Hi,
>> > this is really great, many thanks! I am looking forward to add a
>> > temporal
>> > modules menu layout.
>> I was about to suggest adding temporal framework to the toolboxes so
>> that it can be optionally added to menu. Will you try it? The needed
>> information should be in the programming manual. Or I can create the
>> toolbox and you can improve it later. The main work beside creating
>> the structure is to add menu labels.
> That is nice, i would like to improve it later. :)
Sure, try r56081. Copy gui/wxpython/xml/main_menu.xml to
$HOME/.grass7/toolboxes/main_menu.xml
and add line:
<subtoolbox name="Temporal"/>
to appropriate place.
Now start gui and you should see it in menu.
I am sure you'll have to adjust the menu (structure, labels), it's in
file gui/wxpython/xml/toolboxes.xml. There are problems how to make
the labels not so long, so I use 'raster dataset' instead of 'space
time raster dataset' and so on. Also I am not sure about naming
raster3D x volume.
Best,
Anna
> Best regards
> Soeren
>> Anna
>> > Best regards
>> > Soeren
>> > 2013/4/30 Vaclav Petras <wenzeslaus at gmail.com>
>> >> Hi all,
>> >> first version of toolboxes for wxGUI is released (for GRASS GIS 7) and
>> >> is available in trunk. The main purpose of toolboxes is the wxGUI menu
>> >> customization. The current implementation of toolboxes does not
>> >> influence the set of installed or available modules. The toolboxes are
>> >> the possibility to create different highly specialized menu layouts.
>> >> Users, which are able to edit XML, can now create toolboxes which
>> >> contain modules from GRASS distribution, existing toolboxes (from the
>> >> distribution) and modules from addons or their own modules. These
>> >> toolboxes or set of toolboxes (in the toolboxes file) can be copied
>> >> and shared, and users, which are able to copy the file into the
>> >> .grass7 directory, can use them. Note that distribution of toolboxes
>> >> is now not connected to the distribution of modules itself. GUI
>> >> front-end is not available.
>> >> The main menu (main menubar) is treated separately in the separate
>> >> file with slightly different structure but its very similar to toolbox
>> >> and it follows the same concepts.
>> >> Note that you need to create your custom toolboxes.xml file or
>> >> main_menu.xml file into your $HOME/toolboxes directory to see
>> >> toolboxes in action.
>> >> For the detailed description please see Programmer's Manual [1] and
>> >> for future consideration and development issues see Trac [2].
>> >> Anna and Vaclav
>> >> [1] http://grass.osgeo.org/programming7/wxguitoolboxes.html
>> >> [2] http://trac.osgeo.org/grass/wiki/wxGUIDevelopment/Toolboxes
>> >> (links will work soon)
>> >> _______________________________________________
>> >> grass-dev mailing list
>> >> grass-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
