[GRASS-user] Processing LiDAR data in GRASS GIS
Benjamin Ducke benducke at fastmail.fm
Fri May 3 04:21:32 PDT 2013
On 05/03/2013 01:18 PM, Hamish wrote:
> jr.morreale wrote:
>> Then what would be the limit for grass7 with 4gb of ram, no
>> topology/database ? Can it handle billions of points ?
In my experience, it can (even GRASS 6), if:
a) you rasterize the input data directly (r.in.xyz,
as suggested by Hamish).
b) your file system supports files > 4GB (which really
just about anything except a VFAT formatted USB drive
should these days)
and
c) (in case you want to export the results for use
with another GIS) your GDAL has a GeoTIFF driver
that has 64 bit BigTIFF support enabled.
To save storage space, use single precision
floating point data if you can.
Best,
Ben
> I don't really know to be honest. Try the experimental approach
> and keep an eye on `top`, and let us know the results. :) See the
> grass wiki FAQ for a hint on adding temporary swap space on Linux
> if you need it.
> r.in.xyz can handle many billions of points without trouble for
> non-exotic statistical aggregations; memory use there is more a
> matter of raster region size and you can do multi-pass if memory
> is an issue on a really really huge region.
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Dr. Benjamin Ducke, M.A.
{*} Geospatial Consultant
{*} GIS Developer
