[GRASS-user] r.fuzzy.sytem rule file syntax error
Johannes Radinger johannesradinger at gmail.com
Tue May 7 02:35:44 PDT 2013
I try to use the r.fuzzy.system tool but my rules do not work. The error
seems to be related
with a line in the rule definition file. The line is:
$ low {(depth=veryhigh & (velocity=medium | velocity=high)) | ((depth=high
& (velocity=high | velocity=veryhigh)) | ((depth=medium &
velocity=veryhigh) | (depth=low & velocity=verylow)))}
ERROR: line 2 Syntax error near < )>
However that does not give me the real info about the problem. I checked
several times the number of opening and closing braces")" but somehow I
can't find the syntax error. Probably I am just code-blind :)
Any suggestions? Is there any possibility to check the syntax resp. to pin
down where excaclty the problem is?
/johannes
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130507/411d9c79/attachment.html>
