[GRASS-user] How to only get the max value by using v.rast.stats command?
Daniel Victoria
daniel.victoria at gmail.com
Tue May 7 04:12:28 PDT 2013
If you are using some *nix OS, take a look at the awk manual, that will let
you select a specific column.
On May 7, 2013 3:34 AM, "dehuiw" <dehuiw at gig.ac.cn> wrote:
> Hi all,****
> I only need get the max column, not all the statistic columns (n, min,
> max, range, mean, stddev, variance, coeff_var, sum). How can I set the
> parameters?****
> Thanks!****
> Dehui Wang****
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130507/4756c197/attachment.html>
