[GRASS-user] OT: Tips for installing grass in archlinux
    Ahmadou Dicko
    dicko.ahmadou at gmail.com
    Thu May  9 00:19:54 PDT 2013
I moved from Debian to ArchLinux and used to use GRASS 7 in Debian.
The main difference / problem when you want to install from source is
Python.
In ArchLinux the default is Python  is Python 3, so if you want to build
your own GRASS from scratch you have to use some tricks and tell GRASS to
use Python 2.
If someone is interested I can post how I succeed to build GRASS 7 in Arch
Linux.
On Thu, May 9, 2013 at 3:22 AM, Mayeli Sanchez Martinez <
acciondirecta at ada.org.mx> wrote:
> On 08/05/13 10:57, Pietro wrote:
> > Hi Mayeli,
> > On Wed, May 8, 2013 at 4:56 PM, Mayeli Sanchez Martinez
> > <acciondirecta at ada.org.mx> wrote:
> >> Hi everybody! i was using grass on Debian and working great! but now i
> >> need install GRASS in ArchLinux in a laptop, so someone have a tip for
> >> that?
> > I'm using archlinux too, the easiest/fastest way is to build grass using
> AUR:
> > https://aur.archlinux.org/packages/?O=0&K=grass
> > best regards
> > Pietro
> Thanks a lot Pietro, finally I finish the installation of grass64 and
> apparently all is right!!!
> Mayeli
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Ahmadou H. DICKO
statistician and applied economist (ISE)
PhD student in Climate change economics
Faculty of economics and managment - Cheikh Anta Diop University
West African Science Service Center on Climate Change and Adaptated Land
Use (WASCAL)
Center for Development Research (ZEF) - University of Bonn
email : ahmadou.dicko at ucad.edu.sn
twitter : @dickoah
github : github/dickoa <https://github.com/dickoa>
tel : +221 33 827 55 16
portable: +221 77 123 81 69
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130509/9ad7f283/attachment-0001.html>
