[GRASS-user] Query: number of 'areas' reported in v.build output does not necessarily represent different geographical areas
Markus Metz
markus.metz.giswork at gmail.com
Thu May 9 05:32:00 PDT 2013
On Thu, May 9, 2013 at 8:05 AM, Nikos Alexandris
<nik at nikosalexandris.net> wrote:
> RichardC wrote:
>> Hi,
>> Snapping gives the maximum distance to another vertex in map units, degrees
>> for latlon.
>> I don't know the coordinate ref system for the world mangrove shapefile,
> Here a link to it: <http://data.unep-wcmc.org/datasets/21>. For the records,
> ogrinfo reports:
> INFO: Open of `usgs_mangroves2.shp'
> using driver `ESRI Shapefile' successful.
> Layer name: usgs_mangroves2
> Geometry: Polygon
> Feature Count: 1432891
> Extent: (-179.950672, -38.762073) - (179.987788, 32.350173)
> Layer SRS WKT:
> GEOGCS["GCS_WGS_1984",
> DATUM["WGS_1984",
> SPHEROID["WGS_84",6378137.0,298.257223563]],
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.0174532925199433]]
> [cut]
>> but if degrees lat/long, a snapping distance of 0.000001 would equate to
>> ~0.1 m at the equator, which should be sufficiently small?
> My post's target was the (as Markus Metz wrote:) "suggestion of a reasonable
> (assuming floating point rounding errors) threshold for snapping".
> I'd like to have a confirmation that, given that an error message/suggestion
> appears still after using a snapping distance of 1e-14, it means that the
> imported vector map couldn't automatically be topologically cleaned and needs
> some manual handling.
Try to import with snap=1e-13
then try to import with snap=1e-12
then try to import with snap=1e-11
then try to import with snap=1e-10
etc.
stop when there are no more errors
Markus M
>> Does using smaller values improve topology?
> Is this a generic question or about the Global Mangroves vector map? If
> generic, I don't think that topology is improved by using smaller values. If I
> am not wrong, from things learned here and off-list as well, large(er)
> snapping values might cause unwanted damage to the shape of the original data.
> Thanks, Nikos
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
