[GRASS-user] make error in grass7_trunk/man
Johannes Radinger johannesradinger at gmail.com
Mon May 13 06:02:12 PDT 2013
Thank you for that answer. I am not sure if I am
able to understand the problem in all details resp. to solve the problem.
So does these changes in the keywords-list (in the main.c?) involve lots of
work or are just minor changes necessary?
I am just asking as I want to use the r.fuzzy tool in GRASS7
and need to adapt a single code line (in local_proto: #define STACKMAX 50
(line 21))
which makes a the selfcompilation necessary.
So maybe it is possible to update the r.fuzzy tools to be successfully
compiled
with GRASS7.
Thanks,
/Johannes
On Mon, May 13, 2013 at 2:05 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Johannes Radinger wrote:
> > I just tried to build GRASS7 on Ubuntu with the r.stream.* and r.fuzzy
> > add-ons in the scripts-folder (the subdirs have been added to the
> makefile
> > in the scripts folder).
> > When running make I face a compilation error in the /man subfolder:
> > VERSION_NUMBER=7.0.svn VERSION_DATE=2013 python ./build_keywords.py
> > /usr/local/src/grass7_trunk/dist.i686-pc-linux-gnu/docs/html
> > Traceback (most recent call last):
> >   File "./build_keywords.py", line 38, in <module>
> >     key = "%s%s" % (key[0].upper(), key[1:])
> > IndexError: string index out of range
> > Any idea where to look for the problem?
> It appears that one of the HTML file has a keyword list which begins
> or ends with a comma.
> The KEYWORDS section is in the portion of the HTML file is generated
> by running the module with the --html-description flag.
> AFAICT, the problem is due to r.fuzzy.* not having been updated in
> response to r38061, which changed the "keywords" field of struct
> GModule from a single string (char*) to a list of strings (char**).
> Since that change, assigning a string to module->keywords is an error
> (although it will only result in a warning during compilation).
> Keywords must be set with either G_add_keyword() or G_set_keywords().
> As a result, I'd expect those modules to crash when run with any of
> the options which output usage information (--help,
> --html-description, --interface-description, etc).
> This kind of "bit rot" is an inherent problem with having modules in a
> separate "add-ons" repository. FWIW, r38061 was made almost 4 years
> ago (2009-06-24).
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130513/a8391876/attachment.html>
