[GRASS-user] make error in grass7_trunk/man
Mon May 13 10:20:01 PDT 2013
Johannes Radinger wrote:
> Thank you for that answer. I am not sure if I am
> able to understand the problem in all details resp. to solve the problem.
> So does these changes in the keywords-list (in the main.c?) involve lots of
> work or are just minor changes necessary?
> I am just asking as I want to use the r.fuzzy tool in GRASS7
> and need to adapt a single code line (in local_proto: #define STACKMAX 50
> (line 21))
> which makes a the selfcompilation necessary.
> So maybe it is possible to update the r.fuzzy tools to be successfully
> compiled
> with GRASS7.
AFAICT, it's just a case of replacing:
    module->keywords = _("raster, fuzzy logic");
with:
    G_add_keyword(_("raster"));
    G_add_keyword(_("fuzzy logic"));
