[GRASS-user] GRASS 6.4.RC3 GUI not starting on windows & GRASS 7 not launching at all
Markus Metz
markus.metz.giswork at gmail.com
Mon May 13 08:10:36 PDT 2013
I had the same problem and found out that a system-wide Python
installation (2.7.2, independent of GRASS) caused the trouble.
Uninstalling the system-wide python helped, but this may not be an
option for many users, because other software might rely on a
particular python version installed.
Markus M
On Mon, May 13, 2013 at 1:29 PM, Hanan Karam
<HananKaram at esinternational.com> wrote:
> Hi everyone,
> I downloaded the Windows binary for Grass 6.4.3RC3 (dated April 20, 2013,
> available on http://grass.osgeo.org/grass64/binary/mswindows/native/) and
> installed it on my Windows PC (6-4 bit, running Windows 7).
> I got the following error message on start-up.
> Starting GRASS ...
> Traceback (most recent call last):
> File "C:\GRASS643RC3\Python27\lib\site.py", line 563, in <module>
> main()
> File "C:\GRASS643RC3\Python27\lib\site.py", line 545, in main
> known_paths = addusersitepackages(known_paths)
> File "C:\GRASS643RC3\Python27\lib\site.py", line 278, in
> addusersitepackages
> user_site = getusersitepackages()
> File "C:\GRASS643RC3\Python27\lib\site.py", line 253, in
> getusersitepackages
> user_base = getuserbase() # this will also set USER_BASE
> File "C:\GRASS643RC3\Python27\lib\site.py", line 243, in getuserbase
> USER_BASE = get_config_var('userbase')
> File "C:\GRASS643RC3\Python27\lib\sysconfig.py", line 472, in
> get_config_var
> return get_config_vars().get(name)
> File "C:\GRASS643RC3\Python27\lib\sysconfig.py", line 405, in
> get_config_vars
> import re
> File "C:\GRASS643RC3\Python27\lib\re.py", line 105, in <module>
> import sre_compile
> File "C:\GRASS643RC3\Python27\lib\sre_compile.py", line 14, in <module>
> import sre_parse
> File "C:\GRASS643RC3\Python27\lib\sre_parse.py", line 17, in <module>
> from sre_constants import *
> File "C:\GRASS643RC3\Python27\lib\sre_constants.py", line 18, in <module>
> from _sre import MAXREPEAT
> ImportError: cannot import name MAXREPEAT
> Error in GUI startup. If necessary, please
> report this error to the GRASS developers.
> Switching to text mode now.
> Hit RETURN to continue...
> I also tried with the most recent WinGRASS binary snapshot: 6.4.3svn-r56225,
> and got the same result.
> I also tried download and installing the most recent binary snapshot of
> winGRASS 7: r56229, and that wouldn’t start at all.
> I have winGRASS 6.4.3 RC2 working fine on my PC. A previous binary snapshot
> of winGRASS 7 (about a month old) was also working fine, but I uninstalled
> it to install the most recent version.
> I appreciate any ideas you have on what might be going wrong.
> Thank you,
> Hanan
> This message has been scanned for malware by Websense. www.websense.com
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
