[GRASS-user] Failed export of vector, missing attribute column
Micha Silver
micha at arava.co.il
Thu May 16 02:01:59 PDT 2013
On 16/05/2013 11:48, Johannes Radinger wrote:
> Hi,
> I wanted to export a point vector to a .shp file. This works except for
> a column that does not get exported. I have tried it in grass70 and
> grass65 (in Ubuntu)
> but both without success. The attribute column that is not exported
> was created
> in the attribute table view and populated with a sqlite-command. The
> column
> is of type DOUBLE and stores the value 0.5 for all points.
> Here the error (in grass65, but the same in grass70) :
> v.out.ogr -e --overwrite input=barriers at PERMANENT type=point
> dsn=/path/to/output
> Warning 1: Field Riv of width 1000 truncated to 255.
> Warning 1: Field Site of width 1000 truncated to 255.
> Warning 1: Field type of width 1000 truncated to 255.
> ERROR 6: Failed to add field named 'passability'
> Exporting 20 geometries...
Maybe the name "passability" is too long? The dbf component of a
shapefile is limited to column names of 10 characters.
> What is the reason for that and how can it be solved?
> Best regards,
> Johannes
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
GIS Consulting
052-3665918
http://www.surfaces.co.il
