[GRASS-user] RE : RE : Merge polygone with same attribut of a shapefile
Nikos Alexandris nik at nikosalexandris.net
Thu May 16 13:38:26 PDT 2013
BLANDENIER Lucien wrote:
> Ok, but I will obtain statistics for each polygons separately and not a
> "global" statistic considering all the polygons of a same category?
If I understand your aim, I think you can have your Polygons map and attach to
it 2 layers.
The 1st layer would contain 1 category value for all features of your
interest, e.g. areas (each defined as a "boundary + centroid"). Then,
"v.rast.stats" will operate on the category/-ies values for all/-multiple
areas queried.
In the 2nd layer, you can define a unique category for each vector feature.
So, the stats should be single-vector-feature oriented.
Funny, I am "stuck" as on how to (re-)define in layer 2 the "cat" column with
unique categories for each (internal) feature id.  There is nothing that
helps-out towards this (simple?) task in the manuals (v.to.db).
Any help?
Nikos
[rest deleted]
