[GRASS-user] g.extension error installing install r.hazard.flood
RichardC
richtcooper at hotmail.com
Sat May 18 02:56:07 PDT 2013
Maybe I was too quick to say this was resolved.
I just can't seem to start r.fuzzy.logic
Before starting GRASS I set the GRASS_ADDON_PATH as follows:
$export =/home/user/.grass6/addons (also tried
/home/user/.grass6/addons/bin)
export GRASS_ADDON_PATH
echo $GRASS_ADDON_PATH
This doesn't seem to be reflected in /home/user/.grass.bashrc ?
After starting GRASS, running r.fuzzy.logic doesn't start the module form
the Layer Manager
When I attempt to run from the GRASS terminal by inserting the path to the
executable I get the error:
Unable to fetch interface description for command 'r.fuzzy.logic'.
Details: [Errno 2] No such file or directory
Try to set up GRASS_ADDON_PATH variable
What am I not doing correctly with the GRASS_ADDON_PATH?
Richard
View this message in context: http://osgeo-org.1560.x6.nabble.com/g-extension-error-installing-install-r-hazard-flood-tp5053923p5054138.html
Sent from the Grass - Users mailing list archive at Nabble.com.
