[GRASS-user] g.extension error installing install r.hazard.flood
RichardC
richtcooper at hotmail.com
Sat May 18 03:38:29 PDT 2013
Some observations that might help identify if my system is in error?
I've added the following to .grass.bashrc
GRASS_ADDON_PATH=/home/rcooper/.grass6/addons/bin
export GRASS_ADDON_PATH
However, I can only run the r.fuzzy.logic extension if I also set the
GRASS_ADDON_PATH in a terminal and run the run grass from the same terminal
(I cannot run the extension if starting GRASS from the menu)?
View this message in context: http://osgeo-org.1560.x6.nabble.com/g-extension-error-installing-install-r-hazard-flood-tp5053923p5054142.html
Sent from the Grass - Users mailing list archive at Nabble.com.
