[GRASS-user] Import conditioned DEM from HydroSheds
Nikos Alexandris nik at nikosalexandris.net
Sat May 18 05:44:47 PDT 2013
Johannes Radinger wrote:
> Hi,
Hi Johnanes!
> I'd like to use the conditioned DEM from HydroSheds (15sec resolution)
> in GRASS to extract rivers etc. using r.watershed. On the HydroSheds-
> Website (http://hydrosheds.cr.usgs.gov/dataavail.php) there are two possible
> file formats: bil and esri grid.
> The esri grid folder for Europe (eu_dem_15s) contains several files all
> with .adf ending and metadata (htm, xml).
> The bil folder contains the eu_dem_15s.bil and a *.hdr and *.prj and some
> more.
> Which format is prefered for importing into GRASS? I guess its the .bil as
> there is only
> one bil-file with the different addtional info (header, projection etc.).
> Which format type
> is the .bil in r.in.gdal?
I guess (BIL is simply, well as we all know, "Binary Data Interleaved per
Line", and) what matters is to have beforehand a Header file (the .hdr).  It
might be ESRI's "EHdr -- ESRI .hdr Labelled" type of file or ENVI's "ENVI -
ENVI .hdr Labelled Raster".
# check...
gdalinfo --formats | grep .hdr
  ENVI (rw+v): ENVI .hdr Labelled
  EHdr (rw+v): ESRI .hdr Labelled
Also, what does "gdalinfo" on the "*.hdr" files of yours say about?
Importing should be straightforward using "r.in.gdal".
...ok, looking closely: I've downloaded one of the files:
<http://earlywarning.usgs.gov/hydrodata/sa_15s_zip_bil/ca_dem_15s_bil.zip>.
#unzip, checking
gdalinfo ca_dem_15s.bil -nogcp -nomd -nofl
Driver: EHdr/ESRI .hdr Labelled
Files: ca_dem_15s.bil
Size is 14160, 6000
Coordinate System is:
I think it should be easy to import.
Best, Nikos
> /Johannes
[0] <http://www.gdal.org/frmt_various.html>
