[GRASS-user] GRASS7 temporal GIS database questions
Sören Gebbert
soerengebbert at googlemail.com
Fri May 24 05:31:23 PDT 2013
Hi Rainer,
2013/5/22 Rainer M. Krug <Rainer at krugs.de>
> Hi
> I am doing spatio-temporal simulations with R and GRASS and IO am
> thinking about using a temporal GIS database to store the resulting
> raster layers in.
> But I have a few questions about the temporal GIS database:
> 1) If I register a raster map in a temporal GIS database via r.register,
> can I delete the original raster map and the info is stored in the
> temporal GIS database?
Yes, the info is still stored in the temporal database, unless you call
t.support with -m option.
> 2) If 1) is possible, can I extract the raster layer again from the
> No, that's not possible since only the spatio-temporal extent and some
metadata is stored in the temporal database. The map data itself will not
copied.
> 3) Summarizing: Is the temporal GIS database a good archiving place for
> the layers I create during the simulation?
If you think that GRASS is a good archiving place then yes. But be aware
that a large temporal database with lots of maps with slow down the
temporal database access. If you want to store >10.000 maps, then you
should use postgresql as temporal database backend.
Best regards
Soeren
> Thanks,
> Rainer
> Rainer M. Krug
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- n�chster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130524/0afe509b/attachment-0001.html>
