[GRASS-user] r.viewshed Python Script OSError
Markus Metz markus.metz.giswork at gmail.com
Sun May 26 13:27:31 PDT 2013
On Fri, May 24, 2013 at 11:32 PM, Martin Lacayo <mlacayo at stanford.edu> wrote:
> Hello,
> I am using GRASS 6.4 on Debian. I am trying to make a call to
> r.viewshed from Python, but it fails with the following exception:
> OSError: [Errno 2] No such file or directory
> Any suggestions?
Did you install r.viewshed?
Where is the r.viewshed binary?
Is the location of r.viewshed in the PATH (within GRASS, test with
"echo $PATH")?
Did you execute the python script from within GRASS?
Which GRASS 6.4 version are you using? Recommended is 6.4.3.svn.
Markus M
