[GRASS-user] Trying to reclassify raster using non-linear functions in GRASS
Vaclav Petras
wenzeslaus at gmail.com
Fri Nov 8 14:21:55 PST 2013
On Fri, Nov 8, 2013 at 8:14 AM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Gabriel Zorello Laporta wrote:
> > I am using ArcInfo Workstation and Grid in order to to produce Gaussian
> > functions of elevation from a DEM with minimum value at 800m, as follow:
> > elev_x800 = elev90 - 800
> > elev_x800sq = pow(elev_x800, 2)
> > elev_x800sqn = -1 * elev_x800sq
> > elev_x800sqnd = elev_x800sqn / 500000
> > elev_x800exp = exp(elev_x800sqnd)
> > elev_x800gaus = elev_x800exp * 0.000798
> > elev_x800gi = (elev_x800gaus * -11330) + 10.044
> > I was wondering how to apply that in GRASS (because I want to move
> towards
> > Open Software). Can you help me?
> You should be able to use those exact same expressions in r.mapcalc,
> e.g.
> r.mapcalc <<EOF
> EOF
> The above will write out each step as a map; if you only need the
> final result (elev_x800gi), you can omit all of the intermediate steps
> and use e.g.:
> r.mapcalc "elev_x800gi = (exp(-((elev90 - 800)^2) / 500000) *
> 0.000798 * -11330) + 10.044"
> Or, if you want to keep the expressions in the above form but only
> want the last one written out as a map, use eval(), e.g.:
> r.mapcalc <<EOF
> eval(elev_x800 = elev90 - 800,\
> elev_x800sq = pow(elev_x800, 2),\
> elev_x800sqn = -1 * elev_x800sq,\
> elev_x800sqnd = elev_x800sqn / 500000,\
> elev_x800exp = exp(elev_x800sqnd),\
> elev_x800gaus = elev_x800exp * 0.000798)
> EOF
> This is an interesting feature. I added this example to r.mapcalc manual
in G7 [r58173].
It is in Notes section. I was not sure where to put it and it is only a
dummy example. Maybe, it would be helpful to have this "Gaussian functions"
example in examples but I don't know what it is, so I don't want to write
about it.
It is bit unfortunate that this example does not work in mapcalc in wxGUI.
I'm not sure if it is a serious issue and where to mention it
(manual/gui/...).
Vaclav
https://trac.osgeo.org/grass/changeset/58173
PS: MarkusN, I've tried to do it I passive voice this time.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131108/91312436/attachment.html>
