[GRASS-user] d.mon error (X11 problem?)
Vaclav Petras
wenzeslaus at gmail.com
Mon Nov 11 18:52:27 PST 2013
Hi Lee,
this is bit off topic but you mentioned that you are returning to GRASS,
and as d.mon user you may be interested in the fact that in GRASS 7 there
is no `d.mon x0` but `d.mon wx0` which is wxPython-based and in fact
similar to Map Display in the main GRASS GUI (wxGUI).
Vaclav
On Mon, Nov 11, 2013 at 9:25 PM, William Kyngesburye
<woklist at kyngchaos.com>wrote:
> It's possible that the XQuartz libraries are not compatible with the old
> X11, which the current GRASS binaries are built with. GRASS would need to
> be recompiled for XQuartz.
> On Nov 11, 2013, at 8:12 PM, Lee Eddington wrote:
> > Marvin,
> > I've downloaded and installed XQuartz but I'm still getting the same
> error. I've tried starting X11 before GRASS and starting GRASS from the
> xterm command line, but no luck.
> > Thanks,
> > Lee
> > On Mon, Nov 11, 2013 at 4:34 PM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
> > Starting with 10.8 (I think) Apple stopped providing an X11 package.
> You need to download and install X11 (XQuartz) on your own now.
> > xquartz.macosforge.org
> > (doesn't seem to be responding at the moment)
> > On Nov 11, 2013, at 1:51 PM, Lee Eddington wrote:
> > > I’ve recently started using GRASS again after a few years and I don’t
> remember a lot. I previously worked with it for just a few months and was
> able to get some work accomplished, but I’m still a novice. I’m working on
> a Mac with Mac OS X 10.9 and when I try to open a display monitor from the
> command line I get the following:
> > > GRASS 6.4.3 (bali_d03):~ > d.mon x0
> > > ERROR: no such monitor 'x0'
> > > ERROR: No such monitor as <x0>
> > > Problem selecting x0. Will try once more
> > > I went back to my old system that I used GRASS on before (GRASS
> 6.4.0RCS running Mac OS X 10.6.8) and d.mon x0 worked fine.
> > > Any help would be appreciated.
> > > _______________________________________________
> > > grass-user mailing list
> > > grass-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/grass-user
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > "I ache, therefore I am. Or in my case - I am, therefore I ache."
> > - Marvin
> "The beast is actively interested only in now, and, as it is always now
> and always shall be, there is an eternity of time for the accomplishment of
> objects."
> - the wisdom of Tarzan
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131111/fc93bdb1/attachment.html>
